B Brett145 Prominent Mar 1, 2017 5 0 510 Mar 4, 2017 #1 So I got all the way to the end of my pc build turned on the computer and got a error 55 code on the motherboard. The motherboard is a z170x-ud3 and ram is Team Dark 16GB (2 x 8GB) 16gb 3000 is the ram and motherboard and ram not compatible?
Solution alexoiu Mar 5, 2017 Have you properly inserted the RAM in the slot? Some require a bit more force. Try leaving single RAM module installed and testing each slot.
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Mar 5, 2017 Solution #2 Have you properly inserted the RAM in the slot? Some require a bit more force. Try leaving single RAM module installed and testing each slot. Upvote 0 Downvote Solution
