error on hard drive how do you get rid of it
Jeremy Duval
14
hard drive has a error it has a yellow ! and says num ultradma crc errors value 200 worst 200 0000000000-0000 051 i have done other hdd test only one that finds this error or any error is hddscan. any way to fix it? thanks
even tho i check other hard drive testing programming. like western digital and checkdisk crystaldiskinfo. etc and only hdd test showed me that error.? its not a error with maybe the windows?
How risky do you feel with your data?
Well, if it is still under warranty, start a discussion with the manufacturer for a replacement.
If not under warranty, consider that any data you put on it from now forward may be gone at any moment.
