Question Ethernet and WiFi
Jun 8, 2025
13
So i have problem with ethernet. When im connected via ethernet pages on chrome and league of legends for example load very slowly. Loading youtube for example takes time, pages load very very slowly while on WiFi its working very good pages load very fast and everything is going smoothly (only sometimes i get disconnected in games for 2-3 seconds thats why i dont want to use wifi). Ethernet in games and download speed works very good, only loading pages is the problem. So i have been switching between lan and wifi. This happened when my internet provider changed my modem. On my old modem it worked very good but i cant change back now :). Any solutions?
[td]Vendor[/td][td]Ubee Interactive Corp.[/td] [td]Model[/td][td]EVW32C-0N-010[/td]
On idle on ethernet
Pinging www.google.com [142.251.39.68] with 32 bytes of data:
Reply from 142.251.39.68: bytes=32 time=28ms TTL=117
Reply from 142.251.39.68: bytes=32 time=26ms TTL=117
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 26ms, Maximum = 28ms, Average = 27ms
When opening youtube and pinging on ethernet
:Reply from 142.251.39.68: bytes=32 time=705ms TTL=117
Reply from 142.251.39.68: bytes=32 time=217ms TTL=117
Reply from 142.251.39.68: bytes=32 time=30ms TTL=117
Reply from 142.251.39.68: bytes=32 time=27ms TTL=117
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 27ms, Maximum = 705ms, Average = 244ms
On WiFi
Reply from 142.251.39.68: bytes=32 time=14ms TTL=117
Reply from 142.251.39.68: bytes=32 time=13ms TTL=117
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 13ms, Maximum = 14ms, Average = 13ms
WiFi and Youtube
Reply from 142.251.39.68: bytes=32 time=15ms TTL=117
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 14ms, Maximum = 15ms, Average = 14ms
89.216.4.246 / 72.14.219.230 are slow
Do it again on wifi
C:\Windows\System32>tracert youtube.com
Tracing route to youtube.com [142.250.201.206]
over a maximum of 30 hops:
1 1 ms <1 ms 3 ms 192.168.0.1
2 6 ms 7 ms 7 ms 10.70.0.1
3 9 ms 7 ms 11 ms sa-he-m-10-be3.sbb.rs [89.216.4.246]
4 9 ms 10 ms 8 ms bg-ne-m-0-be40.sbb.rs [89.216.6.158]
5 9 ms 9 ms 9 ms bg-tp-m-0-hg7-2.sbb.rs [89.216.5.248]
6 14 ms 13 ms 13 ms 72.14.219.230
7 18 ms 14 ms 13 ms 209.85.245.45
8 13 ms 13 ms 13 ms 142.251.65.221
9 13 ms 13 ms 13 ms bud02s35-in-f14.1e100.net [142.250.201.206]
Trace complete.
1 <1 ms <1 ms <1 ms 192.168.0.1
3 7 ms 6 ms 7 ms sa-he-m-10-be3.sbb.rs [89.216.4.246]
4 9 ms 9 ms 9 ms bg-ne-m-0-be40.sbb.rs [89.216.6.158]
5 8 ms 9 ms 10 ms bg-tp-m-0-hg7-2.sbb.rs [89.216.5.248]
6 13 ms 13 ms 13 ms 72.14.219.230
7 16 ms 15 ms 19 ms 209.85.245.45
8 16 ms 13 ms 13 ms 142.251.65.221
9 14 ms 13 ms 13 ms bud02s35-in-f14.1e100.net [142.250.201.206]
Trace complete.
1 19 ms 19 ms 19 ms 192.168.0.1
2 25 ms 40 ms 26 ms 10.70.0.1
3 114 ms 38 ms 192 ms sa-he-m-10-be3.sbb.rs [89.216.4.246]
4 28 ms 27 ms 27 ms bg-ne-m-0-be40.sbb.rs [89.216.6.158]
5 27 ms 27 ms 27 ms bg-tp-m-0-hg7-2.sbb.rs [89.216.5.248]
6 32 ms 45 ms 42 ms 72.14.219.230
7 546 ms 609 ms 475 ms 209.85.245.45
8 666 ms 33 ms 31 ms 216.239.49.77
9 32 ms 31 ms 32 ms bud02s43-in-f14.1e100.net [142.251.208.174]
wifi
So hopefully I cut and paste this correctly.
Are you 100% sure these are the results from ethernet and wifi. They very much look reversed. The initial delay and random spikes is very common in wifi but not in ethernet. You almost never get 1ms on wifi either.
Also the is a difference in the IP and last hops in the path to youtube. This is a youtube load balancing thing but you have to be careful to test with the same IP even though in this case it makes no difference.
