[SOLVED] Ethernet cable and wireless network
Ragtime6
Hello,
The house is wired to 3 rooms with a router & switch on a fixed IP. I also have a wireless router that is connected to one room with an IP of 192.168.. The airport extreme then gives computers an IP of 10.0.1.. My main computer is on the IP of 192.168.. with the printers, so the wireless computers can't communicate or print to the other network.
How can this problem be solved?
Change your wireless ip to the 192.168.x.x range.
you should be able to use "airport utility" to manually change the Xtreme's IP address. (make sure you are not using the WAN connection on the Xtreme)
