Ethernet cable not working. multiple errors, yellow "!"
Jun 3, 2018
As above, errors include default gateway not available, windows can't communicate with the device or resource, modem experiencing connectivity issues etc. Tried multiple fixes for all errors and nothing has worked. Any advice, could it even be just a dodgy cable?
Maybe but most times you get a red x when it is a bad cable. It Is a cheap thing to try to replace. Otherwise it is likely a driver issue. Try to find the one for your motherboard and reload it. Window 10 unless you disable it will sometime update drivers.....most times it does not hurt unless it is a video driver.
