Hello.
I am dual booting Windows 10 and Kubuntu. On Kubuntu the ethernet cable works perfectly, but on Windows it doesn't work about every second boot up. It just says that it's unplugged and that I should check is it plugged in correctly, but I know it's plugged in because this problem never occurred on Kubuntu.
I can make Windows detect it after disabling and enabling the ethernet a few times.
Usually if I restart after making it detect it, the Internet works. But if I shutdown and wait for some time, and then boot up, it may sometimes not work again.
I also installed Photoshop CS6 and then got Bonjour automatically. I uninstalled it, and checked for it in services, and it's not there, so it should be alright.
I didn't find this specific problem anywhere on the Internet, so I'm posting it here.
Thank you for the help.
