A week ago I got a new PC and it works like a charm aside from the Internet.
I got connection drops every 15 minutes multiple times a day. My connection would work fine for a few hours then start dropping every 15 minutes until it stopped dropping and proceeded to work fine for a few hours.
So I called my ISP and they send an agent who built in a new modem saying ours is outdated which makes sense since it wasn't replaced in 5 years.
He also said that if my connection were to drop again that it isn't their issue but my PC's issue and that getting an Ethernet cable is a much better solution.
I use a TP-Link WN823N adapter which is the same one I used on my previous PC without an issue. I checked that all of the drivers are up to date, tried changing the USB port etc.. and nothing worked.
My connection didn't drop since he installed a new modem (which was around 1.5 hours ago) so I'm wondering if it doesn't drop again should I keep my Wireless Adapter or install an Ethernet cable anyway?
Also, is there any measure in quality for Ethernet cables? My local store has them for $5-7.
