Ethernet connection over 120 metre distance
spacedonkey101
I have a requirement to communicate over a 100MB/sec ethernet segment at a distance of 120 metres. I have read that the maximum segment length is 100m.
Would I need some form of repeater or other hardware to overcome the distance limit?
Can anyone recommend a solution?
Many thanks.
If I am not mistaking, Optic Fiber is the way to go as it can cross longer distances at higher speeds. You'll find them on higher-end switches. The only problem, i believe is that it's not very flexible...
I remember reading from somewhere that standard optic fiber could go further then 4Km.
Using a higher quality cable would solve the problem (such as cat6). Or putting an inline repeater in the line (like a hub) would also solve the problem.
Fiber wouldn't really be cost effective in this situation if all you need is a 100mb connection. Though even if you needed gigabit later I'm sure cat6 would handle it at that range just fine.
The least option, given that you probably already have CAT 5 cable, is to insert a powered switch at/before 90 metres - 100 metres really IS a max - never (well seldom) run at max!
It would need to be a switch. A simple hub or repeater (by definition) will, in fact, cure the single segment eletrical limitation of 100m. However, it will do nothing for the latency requirement of half-duplex ethernet segments (52us in 10Mb, 5.2us in 100Mb). In order for the "CD" part of CSMA/CD to work, there has to be a switch or some kind of store-and-forward, full-duplex device in the middle.
Ok..1)Use converter to extend distance.
Ethernet to fiber optic
2)Use siwtches ro extend
you may look for:
CML Technology in JB www.cmltech.com.my
