[SOLVED] Ethernet connection slows from 400mbps to 100mbps within a few minutes ?
Parroty69
Commendable
Oct 27, 2021
240
7
1,595
My ethernet has 400mbps immediately after plugging and the adapter status for Realtek PCIe Family Controller shows that it has 1 gigabit:
View: https://imgur.com/cGKpHrP
But after a few minutes it slows down to 100mbps in a speedtest and the adapter status says the speed is 100mbps:
View: https://imgur.com/gDpnIuV
I used multiple cables to test it but a cat6 stays at 100mbps the whole time. And a crappy broken cat5e cable that i had lying around (the one that is in the pictures) begins at 400mbps and slows down to 100mbps like I said
Both cables are UTP cables and the cat6 one is a flat cable. Cat 5e cable is round
I think this is a cable issue because trying out different cables give different results. Do you have any suggestions to fix this issue?
Sounds like you have 2 bad cables. The cat5e sounds like it was somehow damaged or is just very old.
The cat6 cable you have is a fake cable. Flat cables have wires that are too thin to meet the specification of ethernet. Because the wire is none conforming you can get all kinds of strange errors.
Buy a cat5e or cat6 cable that is pure copper with wire size 22-24
Not sure but I bet it is. CCA cable is not allowed for any ethernet cables. It would not meet the standards. I forget exactly which standard says the metal must be copper. When the standards where written many years ago CCA cable did not exist so they do not actually say you can't use it they just say the wires need to be made out of copper.
This company appears to make great efforts to sell only certified cable so I doubt they would sell trash cables
There is an article from Commscope back from 2012 about CCA: https://www.yumpu.com/en/document/read/12317237/copper-clad-aluminum-cca-commscope
Do you think it's worth it to buy from this trusted brand over the previous cables that I have selected? The previous one had 23awg and solid. The Commscope cable only costs a bit more.
That's household electrical power using CCA and does not take high frequency issues into consideration because they just don't have to. 60Hz, for USA electrical systems, is pretty far from the frequencies used in networks. The copper cladding on he outside of the Aluminum core causes the signal to reflect within the wire. The cladding acts as a mirror and the interface between the copper and aluminum causes distortion for what signal does come thru. The longer the distance the more the signals becomes a distorted mess.
have a read here: https://www.computercablestore.com/what-cca-wire-can-do-to-your-network
There is an article about Commscope selling their cca and steel assets to Fushi Copperweld here: https://www.cablinginstall.com/cabl...steel-assets-will-close-nc-manufacturing-site
The article says that they will continue to make GroundSmart products.
Does this mean that my cable will not be cca?
