So I recently moved to a new apartment and with the rent comes a network.There is no router so you connect with your cable directly from the wall. When you use it first time it should guide you to a website where you can log in and after you can use it. I have tried to connect with my PC but with no success. With my laptop it works, so the problem doesn't lie on the network provider. I have used similar connections before with no problem. I'm using my phone usb connection atm. Things i have tried:
Reinstalling TCP/IP Settings
Disabling and Enabling my NIC
Changed my network adapter settings
Uninstalled and reinstalled network drivers
My ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-B2PSBSU
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-58-7A-61-D7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 14-DA-E9-03-1E-11
Link-local IPv6 Address . . . . . : fe80::d18f:637c:fa05:4f32%17(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.79.50(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 185916137
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-21-FE-CC-E2-14-DA-E9-03-1E-11
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Please help!
My ipconfig /all
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Please help!
