Hi,
I have a wireless internet booster to increase signal in the other side of the house from where the main router is, and I use an ethernet cable from that to my pc.
I've had a lot of problems with my internet for my pc, whereas other times with the same internet but an ethernet plugged directly into the router it's been fine.
So I was thinking, does the booster being wireless kind of defeat the point of using the ethernet, since it's still using a wireless connection to the main router?
Would like to know if plugging an ethernet cable directly into the main router would improve my internet for my pc, or it there is no point.
NOTE: I don't know how boosters work so if what I'm asking might be really dumb.
Thanks
Thanks
