Question Ethernet issues please help
Holmsey7
72
7
535
I have just upgrade my cpu and motherboard when i go to login to my user it says “ your pin is no longer avaliable due to a change if the security settings, click to setup pin” however my motherboard for some reason is not recognising my ethernet to says i have no connection so it wont allow me to update my pin. What do i do help!!!!
Holmsey7
72
7
535
You should be able to log in another way, like through a password or something. Are you presented with any other options to log in?
Nope it says this as i just moved my ssd to a new cpu and mobo, so i need to change the pin however because my ethernet is not recognising i cannot egt on the internet to change it and cannkt get into my settings either to make the ethernet work or download drivers that could be missing
Holmsey7
72
7
535
Swapping an OS install to a new motherboard can cause problems, such as driver issues and whatnot.
It's normally recommended to install Windows if transferring to a new motherboard to avoid problems.
Ik i was gonna but wanted to see if there was another way, forgot my usb with the install tool at my mums like 3 hours away, gonna buy a new one and do it tomorrow, will it just replace and delete the current windows installed on my ssd?
