Known Issue: My computer recognizes that I am connected to internet (through an Ethernet cable) but will not work. When looking at task manager it says that I am receiving at most a few hundred Kbs but sending 0. Though when looking in ethernet settings it says that the connection is at 100 mb/s but nothing that requires a network connection will work.
Pretty sure its not:
Cable: Tested on other devices and connection is established and working
Wall Port: Also test on another device and connection is established and working
Steps already taken to solve the issue:
Restarted the PC
Full power down and back up
Updated windows
Updated all drivers
Updated BIOS
Updated all BIOS drivers
Checked proxy settings
I have no VPN
Updated power settings
Reset Network
Changed fixed IP
Factory Reset my PC
Factory Reset with Windows media creation tool
Changed to Linux (Mint) Operating System
Something that I think is also really odd: When plugging in my USB Wi-Fi antenna, Wi-Fi works just fine
It is fully possible that I missed something, even that is small. I like to consider myself good with technology, but this is outside my knowledge at this point. At this point it is hard for me to think it is a software issue seeing as it has crossed different Operating Systems (unless there are special drives needed for Linux, that I did not know of seeing as I am not the most familiar to it). Though, if it was a hardware issue why is the computer recognizing it? Also, the lights in the back are flashing that it is working, if it was broken wouldn't those not flash? I have extensively looked over the Motherboard and see nothing wrong, and this happened while it was running. How/ why would the hardware all the sudden break for no reason? Seeing as I use this computer for school, any help would be nice. Let me know if you need anything more (I can go back to windows if that makes it easier to fix).
Computer Specs:
CPU: Intel i9-9900k
GPU: GeForce GTX 1060 3GB (yes, I know I need to upgrade)
Memory: 16gb DDR4 3200 MHz
1 TB HHD
1 TB SSD
Motherboard: Aorus z390 Pro
Sorry that was long, but I thought all the info I could give would make this easier.
Restarted the PC
Updated windows
Updated all drivers
Updated BIOS
I have no VPN
Reset Network
Changed fixed IP
Factory Reset my PC
Computer Specs:
CPU: Intel i9-9900k
1 TB HHD
1 TB SSD
