Question Ethernet keeps disconnecting and reconnecting every second after installing a network switch ?
Jan 10, 2022
Hi guys,
I recently bought a network switch to improve my home network. After plugging the PC into the switch, it keeps disconnecting and reconnecting every second.
My setup is simple, I had:
Router -> PC (via ethernet)
Router -> Access Point (via wifi as a extender)
then to improve the speed on my access point, i bought a network switch, and now it's:
Router -> Switch
Switch -> Access Point (via ethernet) - this works. i even followed the guide on here to disable DHCP and assign IP one increment above master router. It actually works without disabling DHCP too.
Switch -> PC (via ethernet) - this keeps going ON-OFF-ON-OFF....driving me nuts
Some troubleshooting i've done:
  • connect the PC straight to master router, still works like before
  • flushdns, ipconfig release, renew...
  • try every port on the switch
  • reboot every device on the network
  • assign my PC an IP from windows
  • assign my PC an IP from the master router
  • connect the PC to either router via wifi, still works, but i do need to use ethernet for gaming
what I cannot do:
- connect the PC to the access point, it only has one port and it's one of those extenders
So i achieved the improved speed i wanted on the access point, but in the process my PC's ethernet is wonky now. It does have internet, but disconnects every second.
Any advice will be appreciated!
Reference:
" i even followed the guide on here to disable DHCP and assign IP one increment above master router. It actually works without disabling DHCP too. "
But DHCP is off - correct?
Update your post to include make and model information for Modem, Router, Access Point and Switch(s) - if a replacement switch did not/does not work.
