[SOLVED] Ethernet outlet limiting speed
Jul 11, 2024
I did some cable work in my house and what was previously just a big cable from the router connected directly to the PC, I transformed into a Router -> cable -> outlet -> cable -> outlet -> cable -> PC.
Configuration picture: View: https://imgur.com/a/EeHkrvl
I tested both cables individually and I get 1000mbps connection when I connect my PC to the router. All cables are Cat5e and the outlets are Cat6.
When I test the connection using a cable tester it works just fine, all connections are successfully. But when I connect my pc using the outlets I only get 100mbps which is strange.
Any idea of what it could be, I have no more ideas about what it could be, I rewired both outlets twice but the problem maintains.
These are the sockets
https://www.ledkia.com/uk/buy-plugs...123&id_query=37a119642b455354160e49bb884585c8
Here are some pictures with the cover lifted up onthe connections on both ends of the outlets
View: https://imgur.com/a/OkKgyKR
View: https://imgur.com/a/mZeohug
Thanks in advance.
SOLVED: I was wiring the wall socket as if it was a RJ45 connector. Now I wired it correctly and everything is working as expected.
Thank you deeply to anyone who tried to help me.
