So i have a new pc, and a new internet. I have my pc connected directly into the modem. I can connect to the internet well, but after some heavier loads my ethernet plug seems to "freeze"? It thinks its still connected to the router, but when i log into my router via my phone, it isnt connected. Ive also tried to Ping the router from command prompt, but no contact. if i try to unplug the cable, it still says on network connections that its plugged to "(name of modem)" modem. It will not reconnect to it before i either restart the pc, or disable and enable the ethernet port.
I have tried all the different correct drivers i can find for the port. The cable is fine and tested on another pc. I have tried turning off the power management setting. Updated just about anything i possibly can think of, but still no luck. Im tired of having my internet disconnect during important times and having to reset it. So i hope that this is something someone knows off. Thanks
