*Before I posted this same thread in Motherboard section because I'm unsure where to post it, so I'll post it here. LINK TO OTHER THEAD: HERE *
ave been having issues with my Ethernet Ports (Yes I have 2). About 2 weeks ago I thought I would be a genius and give my computer a clean. So I used a can of compressed air and held it up straight to make sure non of the nitrogen or whatever liquid is in the can does not come out and only air. I disassembled my PC to get in the nooks and crannies. When I put it back together my LAN port(s) were not working, so I thought oh well, I'll just go through the whole, Uninstall Driver/Re-Install driver process to no avail.
I finally tested a New OS and to my surprise it worked! so I upgraded from my then OS (windows 7) to the new OS (Windows 8.1) everything was going smoothly until about 2 days ago. My computer decided to install 100 and something updates (None are listed in the update history so I can't tell you what they were.). I turned my computer on in the morning before I went out for the day and left my computer running. I came back to find my computer black screened (Like as if the GFX card crashed) so I restarted my computer to find out the internet no longer works.
I tried installing the drivers from ASRock (My MoBo provider), then tried installing the drivers from Broadcom (Ethernet provider) for the correct lan chipset (BCM57781). None of those worked. I tried restoring to a point before the updates. That didn't work. Tried using the b57udiag utility provided by broadcom and it said no devices found (Or something along those lines) but the main puzzling thing is the BIOS says that both ports are "connected" I'm assuming that it means connected to my board and detected. The lights are constant showing a Green Power and a Orange Speed/Traffic light which blinks every now and then. But no internet nor detection of the re-installed drivers.
If you need anymore details please let me know.
My specs are:
Fujistu 256GB SSD
Seagate 2TB HDD
16GB Corsair Vengeance 1333MHZ High Profile RAM
i5-3570k
Antec HCG 750W PSU
AsRock Fatal1ty Z77Professional
CAT 6 TIA/EIA 568-B2.1 patch cable
ISP provided 4port modem
Side-note(s):
I have tried plugging the Ethernet cable into my laptop and it works.
I have tried changing the port that the cable is plugged into.
I have tried using the device manager to scan for hardware changes apparently there are none
Checked the Event Viewer for something (was hoping it could be a driver problem displayed)
Tried using a different cable - no success.
Currently using my HTC android device USB tethering using the RNDIS provided via microsoft.
Willing to purchase a cheap but decent PCI/PCIe Ethernet NIC/Network Card.
My specs are:
Fujistu 256GB SSD
Seagate 2TB HDD
i5-3570k
Antec HCG 750W PSU
Side-note(s):
