Ethernet wont connect to new built pc, lights on port are on and blinking
Cfawn
Recently built a pc, connected an ethernet cord, not receiving a connection despite green light on router and theres a orange and blinking yellow light on the motherboards ethernet port where the cord is
Search for device manager and see if you have the ethernet driver for your motherboard.
If your drivers are installed and working, open a cmd prompt and type "ipconfig" to see if you get an IP.
If you have an IP, try to issue the "ping" command in the cmd prompt to your routers IP. You can find your routers IP with the ipconfig command, it is called "Default gateway".
Latest posts
