H HahnSolo Reputable Jul 11, 2014 86 0 4,640 Jul 12, 2015 #1 [strike][/strike]40 amps on single 12v rail, safe or no?
Solution D Deleted member 217926 Jul 12, 2015 Power supply requirements here: http://www.realhardtechx.com/index_archivos/Page362.htm The EVGA 500B is a lower end, budget unit no way should you try it when 650 watts is recommended.
smorizio Titan Jan 22, 2010 30,980 11 125,315 Jul 12, 2015 #2 https://pcpartpicker.com/part/xfx-power-supply-pro650wp1650snlb9 about the same price and is a rebranded sesonic unit. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jul 12, 2015 #3 I would get a decent 650w to run a 390. Upvote 0 Downvote
D Deleted member 217926 Guest Jul 12, 2015 Solution #4 Power supply requirements here: http://www.realhardtechx.com/index_archivos/Page362.htm The EVGA 500B is a lower end, budget unit no way should you try it when 650 watts is recommended. Upvote 0 Downvote Solution
