Question EVGA 550 N1, 550W Problem
May 27, 2019
4
Just finished an AMD Ryzen 2200G build used a ASUS B450 MOBO. Crucial MX500 SSD.
When I was done and had checked everything I plugged it in and turned on the PSU. Didn't have anything. Couldn't turn on the PC with the Power button. Nothing. I grabbed the power cord and even though it was seated I wiggled it a bit. It started sparking where the cord plugs in (From PSU) the LEDs came on on the MOBO. Then Nothing. I unplugef everything and took the connections off the MOBO. Still no PSU fan and some sparking @ the back of the PSU.
ANYONE?
Wonder what all is fried if you had to guess.
Sounds like your PSU might be faulty. How OLD is this model ? That isn't the very best of power supplies supplied by EVGA though, build/quality wise that is. Very poor...
I am hoping it didn't take anything else out. I was going to let it lost. Go into the bios and set the ram speeds and a couple of other things then install Arch Linux
