[SOLVED] EVGA CLC 280 water cooler or CORSAIR H100i PRO
boyonfarm
15
I'm trying to decide between the two at the moment I can get the EVGA water cooler for 105 and Corsair for 120 for the 280mm versions. I am also considering the NZXT RL-KRX62 but that goes for 140 and from what I understand the EVGA beats it at mid and high rage RPMS just not on the low end. Also, I own an i7 8700k and Would like to have the option to overclock to 5ghz
The AIO water coolers in question
EVGA: https://www.amazon.com/EVGA-Liquid-Cooler-Cooling-400-HY-CL28-V1/dp/B01N16CAKN/ref=sr_1_1?s=electronics&ie=UTF8&qid=1544822499&sr=1-1&keywords=EVGA+CLC+240+Liquid%2FWater+CPU+280
Corsair: https://www.amazon.com/Radiator-Advanced-Lighting-Software-compatible/dp/B07BWNWQKJ/ref=dp_ob_image_ce
NZXT: https://www.amazon.com/dp/B06XX8Q1CL?tag=amz-mkt-chr-us-20&ascsubtag=1ba00-01000-org00-win10-other-nomod-us000-pcomp-feature-pcomp-wm-3-wm-8-wm-1-wm-4&ref=aa_pcomp_exp2
boyonfarm
15
Thank you for your quick response, that does seem like the best option I also have evga graphics card and power supply so that kinda helps
