Question EVGA Geforce GTC 560 -> Asus GeForce GTX 1050 Ti 4GB - and wow it is 50x slower.
Jul 31, 2021
6
Hello all,
I need some advice. I've been playing Rust on my PC :
Motherboard: ASUS - ROG Strix B450-F Gaming
CPU: AMD Ryzen 5 3600 6 core
GPU: EVGA Geforce GTC 560 - upgraded to Asus GeForce GTX 1050 Ti 4GB
RAM: CORSAIR - Vengeance RGB PRO 16GB (2PK 8GB)
POWERSUPPLY: Corsair HX - 850w
And it was running alright, definitely playable. But I knew a graphics card update would really help me out as the 560 was super old.
So this morning I took the EVGA 560 out and put in Asus GeForce GTX 1050 Ti 4GB
Used the Geforce Experience app to do a clean install and drivers are up to date.
I got on Rust and it was like 10-15 fps 100% GPU utilization. Weirdly enough after 10 minutes of moving around it began working perfectly.
Trial and Error so far
-Yes, my monitor is DVI cabled into my GPU not my motherboard.
-RAM sticks connected
-Maybe Driver Conflict going from EVGA to Asus?? I didn't uninstall anything I just changed cards and did the clean install.
Can someone help? I'd rather not go back to the 560 but at this point at least I could play.
Any ideas?
____
EDIT: I've been messing around and it seems like for a few moments here and there the game will run flawlessly like I would expect it to. These moments are few and far between though. It doesn't make sense. I would love for it to run perfectly as it does in those moments. However, I would 100% trade back to the 560 for the stability of it. I hope that helps diagnose any issues..
Hello, what other PC games have you tried playing on your new GPU, the GTX 1050 Ti ? Is it only RUST, or even other PC games as well ? There is No driver conflict if using the same vendor GPU which is Nvidia in your case, regardless of the brand (ASUS, EVGA etc.).
Of course, we should always do a clean re-install/update of drivers, but conflict usually arises when you are swapping cards from 2 different vendors, like switching from AMD to Nvidia, and vice versa. Anyways, please also list the exact Model number and make/brand of your current 850 Watts PSU.
I just put my 560 back in. At least I can play with it.
The only difference between the 560 and the 1050 is the 560 actually plugs into the power source. Im wondering if Ishould just start looking for a card that uses the power supply?
Corsair HX 850W.
Alright, that's a very good PSU ! No worries here.
Please can you clarify this issue ? Does your particular GPU model require any external 6-PIN PCI-e cable from the PSU ? Because, if I'm not mistaken, being a dual-slot card, the NVIDIA GeForce GTX 1050 Ti does not require any additional power connector, and because of this its power draw is rated at 75 W maximum.
Which one is your GPU from ASUS ? Check this database.
https://www.techpowerup.com/gpu-specs/geforce-gtx-1050-ti.c2885
That one you linked is mine , except mine looks a little different doesnt say Geforce on it but it says Asus.
Here's the ebay link
https://www.ebay.com/itm/194223497081
What I mean by power source connector, in my limited knowledge brain - since my 560 connects to my power supply I feel like I should just order one that actually connects to power supply. Because, as you said, this 1050 doesn't require it. Not that any of that matters I just don't know why it runs like <Mod Edit>. My 560 is back in now and at least I can play.
I just don't see what the issue could be lol
I keep getting told that's not the problem. I was kinda grateful I didn't do that. If you're super confident that's what the issue is, I have my 560 back in and I could redo the whole install..
