EVGA geforce gtx 660 superclocked vs Sapphire Radeon HD 7850 11200-16-20G
superpug
5
My system
Cpu: fx 8320 8 core
Ram: 8 gig ddr3 1600Mhz
Psu:750W
Mobo: Asrock 990fx Extreme 4
Which one performs better overall, ive been doing alot of research on these cards but i cant make up my mind due to the fact the the HD 7850 is 256-bit and the GTX 660 is 192-bit but the 660 is clocked at 1046MHz and the 7850 is clocked at 860 MHz. Would the bits make any difference ex. more bits better, less bits worse.
Mostly i want this card to run well with the upcoming Battlefield 4 which more then likely might be a more graphic card intensive then the current Battlefield 3. Anyways i want better fps for all games in general, which card is better.
superpug
5
by the way my budget would only allow me to choose between these 2, so please just compare these two and not other higher end cards out of my budget.
superpug
5
i have the same processor, hopefully ill buy the GTX660SC tomorrow. and ill probably test this bad boy by next week when and if it arrives from amazon.
Similar threads
