Evga GTX 670 black screen, maxed fan speed
disinfertention
Hello,
I did a few google searched and looked around here to see if I could find a similar crash, but without any luck really. Here is what happened:
My computer was on for about 10 minutes and I opened World of Warcraft. I was away from the computer for a couple minutes, walked back in and sat down. As soon as I did my screens went black and the fan on the GTX 670 ramped up to max speed. I kinda panicked and powered down my computer. I left it for a few minutes to do some searches and then came back in to see if there was a serious problem. All is fine right now.
My concern is if the fan kicking up to 100% like that is a indicator for some kind of problem? I would imagine it would only do that if the card itself was actually hot. Not really sure what's going on here. It has only happened once and I have the game open currently seeing if it will do it again.
This system is about 2 weeks old or so. Here is what I am running.
i5 3570 @ 4.4
ASUS Z77 LK
EVGA GTX 670, latest drivers from Nvidia (dated may I believe)
Corsair TX750
I have yet to have the card go over about 60C and the processor only goes above 50C when I was stress testing it for stability.
Thanks for any advice.
Rick
Fans spinning up to 100% from time to time happen. Did it stay on 100% for long? Or did you turn it off right after it spun up that high? On my current PC my fans will spin up every so often when first opening a couple games.
I have this problem! exact same! i tried reinstalling the nvidia 306.97 driver and it worked!, but then after a couple of days it started crashing again? it staring to irritate me a bit...
Did you ever solve it?
cheers
nvidia drivers default to 20% fan speed, I manually set my to 100 after I bootup and my system never crashes,a bit noisy but livable . have not found a rock solid way of having the fan kickup higher on bootup,tried ntune but it seems a bit flaky
I'm pretty sure that temperature is not the problem because it only crashes after 2 minutes on BF3 and i know that it does not get that hot? , I'm fairly sure it's something to do with the drivers?
Cheers fella, will do :)
