So i have just installed this card in my computer and installed the latest drivers i know that the card does not spin up until it hits over 60 degrees but ive been using it playing games like GTA V At close to maximum settings with a few settings tweaked in order to keep the fps above 60 all times and games like black ops 3 at max settings and MotoGP 15 At 4K Maximum settings and i have noticed my card has been hitting a maximum of 76 Degrees is this something that i need to worry about? i DO NOT Have a custom fan curve set up as i do not know how to do this
Can anyone tell me how i can bring the temps down i have good air flow 2 120MM Fans at the front of the case and a push pull config on my cpu cooler radiator and another fan sat below the graphics card in order to help to move hot air out of the case also i have noticed since upgrading my GPU To the GTX 970 SSC My CPU Seems to be hotter than usual and working harder it typically Sat around 40 - 54 Degrees max while gaming and now it will hit 60 Degrees whilst gaming is this okay? as there is no overclock on the CPU its completely stock and it is watercooled with a 120 Maelstrom CPU Closed loop cooler not the best in the world but it does the job i will list my system specs below and hopefully someone can help me sorry for rambling on im just concerned and dont no to much about computers any advice would be helpfull thanks
SYSTEM SPECS:
Processor: Inter Core I7 4770K @ 3.5GHz -3.9GHz (Stock)
RAM: 12GB DDR3 RAM (Standard RAM Nothing Special)
Motherboard: ASUS B85M-G (Peice Of Shit My Gigabyte Broke)
GPU: EVGA GTX 970 SSC 4GB Edition
Corsair 600M Powersupply
Cooler: Maelstrom 120K Closed Loop Water Cooler
Any Information on how i could get my system temperatures down on my cpu and gpu would be greatly appreciated
SYSTEM SPECS:
