evga hybrid cooler 980 ti
Andrei506
68
i have titan x, i installed evga hybrid cooler 980 ti and its fit and work 100% but i have problem the fan of the gpu run full-speed and back to normal sometime take time to back normal. i try to use afterburner to adjust the fun speed but nothing happened.
anyone can help me with that?
http://www.evga.com/support/manuals/files/980_Ti_HYBRID_Installation_Guide.pdf
1) Fans attached as described?
2) I think the radiator fan runs one speed only.
3) blower fan on card should run based on GPU temperature, and should be adjustable in software (it's not needed for the GPU, only the VRM and memory so it really doesn't need to run at full speed if you can avoid that)
*Verify GPU temperature because I don't see why the fan should be running near 100%. I though the GPU temp would stay under 60degC at all times.
the fun attached to the card, now i attached to motherboard
yes, still run full speed. but the gpu fan
