evga supernova g2 850 fan noise high pitched
Hussein97042
23
hi guys
so when i unboxed the psu i tested it with the 24 pin thing it came with than when i turned eco mode off to see the fan spinning it made a high pitched noise like an old fridge but kinds higher
i can hear it on the other side of my room
is that normal?
just watched the video, couldn't hear the noise you describe
you decide what to do now
i would return the unit if i could, peace of mind on a new pc is something that all of us want, if you find it annoying and a reason to be concerned, you have options, keep it or return it
Are you sure because the airflow is pretty good i Can reel it at the back of the power supply Its just the High pitched noise
I also forgot to say it also kinds sounds like a hard drive but a little louder
