EVGA Teases GeForce RTX 3090 FTW Overclock With 2.1GHz Core
EVGA Teases GeForce RTX 3090 FTW3 With a 2.1GHz Manual Overclock : Read more
Not sure why a 2105 Mhz is so amazing when my 2080 S can generate 2100 Mhz max on MSI Afterburner? These are supposed to be faster than the 2000 series.
I'm sure it'll use 450+ watts too, there's already reports that AIB 3090s have 3x 8pin power connections.... Guess Nvidia consumers don't care about efficiency anymore when it used to be a main part of their battlecry
P.S. Don't take a shortcut to thinking, make a false dichotomy logical fallacy and assume any criticism of Nvidia automatically makes me an AMD fan.... As if there are only two choices in thought
This is made on an 8nm node from Samsung, which is just a refined 10nm. Samsung is also far worse than TSMC.
Is Samsung worse than TSMC in practice though? From what I've read, Samsung 8LPP has more relaxed design rules than TSMC 7N. That might allow you to pack in more transistors than a denser (on paper) but more restrictive process. If your die size for the 3080 is correct, it has around 45 million transistors per mm². Navi meanwhile, only has 41 million transistors per mm².
Samsung 8nm (Ampere RTX 3090) = 44.6 million transistors per mm2
TSMC 7nm (Ampere A100 HPC) = 65.6 million transistors per mm2.
The A100 has a massive amount of cache. As we know, memory cells are packed more tightly. The two chips aren't comparable.
And of course, transistors are no good when unused. Nvidia has to disable 15% of the GA100's cores to reach acceptable yield. Now we don't know how many 3080s Nvidia has to make before they get one 3090. The fact that the two cards are launched concurrently does hint at excellent yield.
Having 10000 cuda cores 2.1Ghz is little different than having 3000 cuda cores @2.1Ghz. 😉Not sure why a 2105 Mhz is so amazing when my 2080 S can generate 2100 Mhz max on MSI Afterburner? These are supposed to be faster than the 2000 series.
But with your knowledge, would you not say the TSMC 7nm appears to be significantly better than the Samsung 8nm even if not to the degree I stated?
"The RTX 3090 already looks like it will deliver incredible performance. Nvidia says it's 50% faster than the outgoing RTX 2080 Ti "
Oh dear!! -->
"3090 = $1499+ for 50% > 2080Ti"
3080 = $699+ for c25-30% > 2080Ti
So, Nvidia asking buyer to cough up an extra $799+ to get and extra c20-25% over the 3080 (i.e. that's including that extra memory) !!!
3090 price-to-performance is shockingly insane in comparison to 3080 !!!
I just built my very first pc, eveything is working fine except for the cpu cooler whenever I turn on the pc the cpu cooler turns on and start glowing but the fan doesn't spin. Is that normal? Does it start to spin when the cpu gets hot? I haven't checked the bios yet so I dont know if I should configure sth there or not.
