Question Existing build won't POST, no error codes after previous start up problems ?
paulod
Commendable
Dec 29, 2022
21
Hi got an issue with my pc which has been intermittent but now appears permanent.
Problem began after pc was left in sleep mode and my wife decided to turn it off at the mains, following that it wouldn't boot and took 4 or 5 presses of the reset button before it would post. Once it started everything would work fine with no issues gaming etc and close down normally.
Next problem my wife (again 🙄) managed to somehow push the reset button into the case meaning the only way to power on / off when it didn't boot was to hold the power button in for a few seconds. This worked for a week or so (I should have bought a new case but was waiting till this weekend as I've been away) but now won't post at all, no beep codes or display
I've swapped memory slots and tried new RAM with no joy.
Tried onboard graphics still no display - ignore this as my cpu has no integrated graphics
Reset CMOS
Only post beep codes I get is when I completely remove memory or unplug power to graphics card.
My mind is pointing towards my power supply but any help much appreciated
PC Specs
Motherboard: ASRock B450M Fatal1ty K4
CPU: Ryzen 7 5700X3D
GPU: Radeon RX 6600
RAM: 2 x 8GB DDR4 CMK16GX4M2B3000C15 at 3000 and 2 x 16GB same RAM at 3200
SSD: Drevo X1 Pro
HDD: Seagate ST2000DM008
PSU: Corsair CV550
OS: Windows 11 Professional 64-bit
