[SOLVED] Expansion Slots - x8 mode for 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors?
Senn
16
Hi,
I have ASUS PRIME B450M-A motherboard: https://www.asus.com/rs/Motherboards/PRIME-B450M-A/specifications/
The specifications state that this motherboard has 1 x PCIe 3.0 but I'm not sure if I understood well this part:
3rd/2nd/1st Gen AMD Ryzen™ Processors
1 x PCIe 3.0/2.0 x16 (x16 mode)
1 x PCIe 3.0/2.0 x16 (x8 mode)
1. Question: Does this mean if you have 2nd or 1st gen Ryzen Processor with integrated Vega graphics, then if you want to add a new graphics card that is PCIe 3.0 x16 (e.g. RX 570) - it will only work in x8 mode?
But, if you have 2nd or 1st without Vega, then the same graphics card will be able to work in x16 mode?
Did I understand correctly? :)
2. Question: I have this motherboard with Ryzen 5 3400G with integrated Vega 11 graphics. I'm not sure if it's really 3rd or 2nd generation (for example, here it's stated that it's more like an updated version of the second-generation).
Will a graphics card that is PCIe 3.0 x16 (e.g. RX 570) only work in x8 mode or it will be able to work in x16 mode?
correct
anything with cpu integrated graphic will run pcie gpu in x8
So, in my case (I have Ryzen 5 3400G with integrated Vega 11 graphics) - if I buy RX 570 or any other graphics card that is x16 - it will only run in x8 mode...
If so, then I guess it's not worth getting such graphics card as it will never be able to reach its full potential ... 😒
I'm not sure how much this x8 mode will affect performance (it will be x2 slower?) but I guess that question should be asked on Graphics Cards section ...
Thanks
