Explore File Problem in SP2 v.2135
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
When I right-click to explore file or folder that contain
some media file type in my HDD, the explore window always
close and go back to the desktop screen (most on .avi
and .rar file type). How could I dissolve this problem ?
Thanks
Hi Suddacha
I would try removing the current version of SP2 from your machine and
installing the final version. The build you are currently running was a work
in progress between Release Candidate 1 and 2 and its quite possible this
problem could just be caused by a bug in the beta version your running. If
you remove the current version of SP2 you should be able to get the final
version through automatic update from Monday or you can download the much
larger network installer from
http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
The current version must be removed before attempting to install the final
version as 2135 is not supported for a direct update.
Mark Salloway
Windows XP MVP
"Suddacha" <anonymous@discussions.microsoft.com> wrote in message
news:630e01c481f8$d8116e30$a401280a@phx.gbl...
> Thanks
