explorer problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
MY xp explorer has recently started locking up periodicly. When it does the
cpu usage is 100% and the only way I can solve the problem is to power down
the computer. All the trouble shooters I have tried shows the system is
normal.
Is there something I can do to solve the problem?
You did not state which Explorer, there are two - Internet Explorer and
Windows Explorer. They are very different.
> normal.
"LilJohn" <jburns@sc.*r*r.com> wrote in message
news:ezB548CxEHA.1392@tk2msftngp13.phx.gbl
> does the cpu usage is 100% and the only way I can solve the problem
> is to power down the computer. All the trouble shooters I have tried
> shows the system is normal.
First eliminate any scumware.
See
Dealing with Unwanted Malware, Parasites, Toolbars and Search Engines
http://mvps.org/winhelp2002/unwanted.htm
Note that AdAware and SpyBot S & D will each catch some things the other
won't. Also, each needs to be updated with the program's update function
before every use, even when just downloaded. There's also a lot more to do
than just those two programs. CWShredder is also available here:
http://www.kellys-korner-xp.com/regs_edits/cwshredder.zip
**Post your HijackThis log to
http://forums.spywareinfo.com/ or the Spyware forum at
http://forum.aumha.org/ for expert analysis, not here.**
Alternative download pages for Ad-Aware, Spybot, HijackThis and CWShredder
may be found on this page:
http://aumha.org/a/parasite.htm.
CAUTION!!!!! Before you try to remove spyware using any of the programs
below, download a copy of LSPFIX from any of the following sites:
http://www.cexx.org/lspfix.htm
http://www.spychecker.com/program/winsockxpfix.html
(if your OS is Win2k or XP) The process of removing certain malware may kill
your internet connection. If this should occur, this program, LSPFIX, will
enable you to regain your connection.
If nothing there helps, please post back to this thread.
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com/security/protect/
