Everything except the peltier I already had in possession, from past ventures.
There were sacrifices made which I would have rather not had to do, but I wasn't using it, so it got sacrificed, I'm referring to my XSPC RASA water block, it's best if you have old leftovers occupying shelves for this type of thing.
A water block is designed completely opposite of what I needed it to do, it is designed to pinpoint cooling to the CPU die location, I needed it to gather cool from the entire copper base contact area, as it was exactly the same size as the peltier.
I modified the water inlet injection protrusion inside the top of the block and shaved an 1/8th of an inch off the depth, and also cut diversion channels in it to quickly disperse the water to the entire base plate, transferring the cold from the baseplate which contacts the cold side of the peltier to the water, and forcing it out the outlet.
This water block modification made it very effective in picking up the cold from the peltier transferring the cold to the base plate.
I tried the Tuniq Tower (the original model), as previously mentioned above, but with only 3 heat pipes, it just could not overcome the heat the CPU was adding to the water.
I had a Thermalright Ultra 120 Extreme on the shelf and used it to cool the hot side of the peltier, it has 6 heat pipes and is very effective at handling the heat produced by the peltier.
Tried multiple combinations of fans in push/pull configuration and settled on 110cfm Sanyo Denki San Ace 120mm fans on a Nexus fan controller, they give the best of both worlds, they're set low speed presently you can barely hear them but when needed they can crank.
I have a lot more info to share but need to decide what's needed regarding what someone would need to know to consider doing this and just stuff learned the hard way.
View Large
View Large
View Large
View Large
View Large
View Large
View Large
View Large
