Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Hello,
This is getting boring.... For what i understand from the inicial post... he
bought a DVD recorder NEC ND-3500 that said no drivers needed if using
Windows XP so it's an external plug'n'play compatible case... it already has
dvd nec nd-3500 inside... in LaCie case you don't have acess to the drive
itself and if you open the case you loose warranty... NEC ND-3500 already
includes NERO
Some chipsets on several boards aren't recognize by Windows XP... so if you
need USB 2 and the chipset isn't being recognize you have a problem...
normally even when the usb2 isn't recognize usb 1 devices still work...
So one of two... either he has a default drive or usb 2 drivers aren't
loaded...
"Nathan McNulty" <nospam@msn.com> wrote in message
news:OjSADYaoEHA.1608@TK2MSFTNGP15.phx.gbl...
> First, the OP said he couldn't even get XP to recognize the drive: "Does
> anyone know what i need to do so that the computer recognizes the burner?"
> If XP does not even recognize a drive was connected, the software sure
> isn't going to. Second, some external casings need you to set the drive
> to Master. Thrid, the chipset drivers contain the USB drivers. Anything
> USB or FireWire is supposed to be plug and play. The ND3500 or ND3510 do
> not come in a USB or FireWire box, you have to put it in one. The drive
> requires no installation whether that be internally or externally, but the
> external casing must be plug and play compatible.
> Nathan McNulty
> André Cruz wrote:
>> Hello,
>> First of all the software might recognize a drive... second of all it's
>> an external drive... so no jumper to set
>> As for the cable it's an usb cable so untill now i never saw one not
>> working out of the box !!!
>> Third of all it doesn't need drivers it's plug'n'play so windows should
>> recognize it automatically i have a LaCie External that uses a NEC 3510 A
>> Drive and Windows recognize it... but i'm using firewire... The problem
>> should be in usb drivers... try find out if your motherboard is using an
>> intel chipset (You can try goto www.intel.com and check for chiputil it's
>> an intel chip detector) and if it's intel chipset try download latest
>> Intel chipset utility... basically what it does it tells os what are the
>> controllers...
>> Good luck...
>> news:%23wcOBNQoEHA.3760@TK2MSFTNGP12.phx.gbl...
>>>It isn't recognizing the drive, so what good would extra software such as
>>>Nero do?
>>>Three thoughts. First, make sure the drive is jumpered to Master.
>>>Second, make sure the cable you are using is good and the port is good.
>>>Finally, install the latest chipset drivers or drivers for the USB port
>>>you are plugging the device into.
>>>You may need to edit the registry a little, but we'll try that if nothing
>>>else works.
>>>Nathan McNulty
>>>André Cruz wrote:
>>>>Hello,
>>>>If you want to burn DVD in XP... yes you need the extra software... try
>>>>Nero to see if it works... it can be a problem with your usb 2.0 device,
>>>>is it an add-on card or it's usb 2.0 ports included in the motherboard,
>>>>if so you may want to check in start-control
>>>>panel-system-hardware-device manager and see in Universal Serial Bus
>>>>controllers if you have an entry no "Enhanced USB" or USB 2.0
>>>>controller...
>>>>"jacksons2003" <jacksons2003@discussions.microsoft.com> wrote in message
>>>>news
😀45D0875-2826-47C3-B43A-600354416EDC@microsoft.com...
>>>>>I bought this burner and it said no software install needed if using
>>>>>windows
>>>>>XP. That is what i am using but when plugging in to my usb 2.0 it says
>>>>>that
>>>>>the device is unable to be recognized. I got on the internet and every
>>>>>site
>>>>>said how easy it was to install and that your device manager should
>>>>>show
>>>>>ND-3500a. Alsot the software that i do have for ther buner windows
>>>>>says that
>>>>>it is not digitally signed. But since i don't need the software when
>>>>>using
>>>>>xp i would not think that it matters. Does anyone know what i need to
>>>>>do so
>>>>>Nick Jackson
>>>>>God Bless
