External Optical Drive for newly built PC?
holmesc
94
Hey guys, I wanted to ask if external hard drives will work if you're using for a newly built desktop pc.
What I'm trying to get at is whether or not a newly built computer (that still needs to install OS) will recognize the USB for a external hard-drive.
The reason why I ask is that I don't use cd's very much and if I can borrow my friends external hard drive to install the OS / Software then i'm pretty much good to go.
Question is, is this do able?
https://www.amazon.com/External-Optical-Notebook-Computer-Dustproo/dp/B00X7DH5GE/ref=sr_1_5?s=pc&ie=UTF8&qid=1486339653&sr=1-5&keywords=external+optical+drive
yes you can, i have a old lg gp08nu20, since 2009 iirc, i use it for that
if the bios or uefi can find a usb dvd drive, it wil work just fine
samsung and lg are the best brands in terms of external optical drives
i do like ore lg, for the build quality and performance overall
the one you listed is a dv drive form a laptop on a external enclosure so no idea what brand is the enclosure or the drive itself
i do recommend you more one like this
https://www.amazon.com/LG-Electronics-Portable-Rewriter-GP60NS50/dp/B00C2AMKR2/ref=sr_1_1?s=pc&ie=UTF8&qid=1486347300&sr=1-1&keywords=lg+external+drive
or like this...
or like this
https://www.amazon.com/Samsung-Portable-External-SE-218CB-RSBS/dp/B00DBV28TG/ref=sr_1_21?s=pc&ie=UTF8&qid=1486347381&sr=1-21&keywords=external+dvd+drive
they do cost more, but you will have that thing for many years, i have mine working for 8 years now and it doesn't show sign of dying soon
consider one like that, they are nice, light and cheap
