Extra fan Connection issue
amitsharma227
161
I am having 140mm bitfenix spectra pro fan i want to installed in my corsair carbide 500r .My mob is biostar ta990fx3 sys fan already attach with it no extra slot now .Is there any solution to use my bitfenix 140mm in my cabinet ?how to connect it ?My psu is corsair hx850
Your motherboard should have another slot for it. There is the CPU fan and at least one other fan. Your fan should have come with an adapter to plug into your PSU, usually converts to a 4 pin molex.
According to the manual for your motherboard, you have three fan headers in total. CPU Fan is at the top, which should already be occupied. SYSFAN1 is at the bottom of your board. SYSFAN2 is right in the middle of your motherboard, right next to the MOLEX connector and above the first PCI-E lane. Hope this helps.
as i mentioned both system fan1 and 2 slot already reserved as well cpu fan slot is also used by using corsair h55 liquid cooler .Is there any other solution to use bitfenix 140, 3 pin fan wire in any connector ?
