Question Extreme stutter and poor performance while gaming and other tasks.
Jan 9, 2025
15
So my PC has been seemingly getting slower and slower. In games, my clicks will take a while to register (not a network issue; the PC is just that delayed and slow), and games will stutter so hard that I'm stuck on a single frame while my FPS counter shows 100+ fps. Even when the game is not "stuttering," 100+ frames does not feel like 100+ frames; instead, it feels more like 30.
My specs:
i7 8700k non-OC
GTX 1080ti
16GB 3600mhz ram 1.45v
240GB Sandisk SSD (Windows boot drive + games)
2TB WD Blue HDD 5400rpm (Storage—pictures, videos, etc)
Asus strix z390F Mobo
H100i v2 AIO
So I had thought it was my CPU overheating, but while stuttering, my max temps were 70-80 degrees. GPU during stuttering is around 79-93 degrees. From what I read, these are fairly normal temps—maybe a little hot, but not too concerning? I've tried throttling my GPU a little bit to see if the lower temps would stop the stuttering, but no luck.
Ive also recently removed all dust, removed old and applied new thermal paste to the GPU and CPU... Still no luck.
Ive been playing mostly Marvel Rivals, which is terribly unoptimized. I play everything on low except for textures and mode detail, which are set to high. I average around 110 fps, but again, it truly feels like 30, and not even a good 30. Meanwhile, my friend plays on one of those mini computers with integrated graphics and still is more stable than mine.
Games and everything I play is on the SSD. Last time I checked BIOS, my SSD wasn't showing in the boot options/priority list, but it still boots and has access to the drive in Windows with no issues. Never updated BIOS. GPU drivers up to date. Can't think of anything else.
If anyone has any info on how I can get my PC back to performing how it used to be, it would be greatly appreciated. Thanks!
You forgot to mention the make and model of you PSU, include it's age as well.
Make and model of your case? Number of fans in your case? How is the AIO mounted in your case?
Have you taxed the system with other titles besides Marvel Rivals?
Never updated BIOS.
BIOS version for your motherboard?
Using DDU, then manually installing the latest GPU drivers in an elevated command?
What is the model of your SSD? Would be a good idea to also see what your firmware for the SSD is at this moment of time.
Never updated BIOS.
You forgot to mention the make and model of your PSU; include it's age as well.
I had recently updated my PSU after my old one failed after 9 years. Its now a Corsair RM750e 750W PSU, and its about 1 year old.
Make a model of your case. Number of fans in your case? How is the AIO mounted in your case?
NZXT S340. 120mm rear exhaust fan, and a 240mm exhaust fan on the roof. The 2 standard fans that came with the AIO were placed at the front as intake. AIO is mounted at the front vertically so that the tubes exiting the radiator are at the top of the case. Fans are placed in front of the radiator so that they are pushing air through the radiator and into the case.
Yes, same issue as well. Just really poor sluggish and delayed performance even when on desktop opening files, browsing, etc. I've tried running Cinebench's standard CPU test, and it takes 10 minutes for it to complete with a score of 400 points total (from the leaderboard of comparing CPUs, <Mod Edit> Mac processors are shown to be running miles faster than mine). Temps while running Cinebench are in the 87-95 range.
Version 2.20.1271.
No, this wasn't done. Originally installed from the NVIDIA website until it prompted me to download the GeForce Experience; from then on, all graphics drivers were installed from there.
What is the model of your SSD? It would be a good idea to also see what your firmware for the SSD is at this moment of time.
SanDisk SDSSDA240G. What do you mean by firmware for the SSD?
I should also mention that my PC has been so slow that it would take 10 minutes to shut down or restart. So every time I go to turn the PC off, its faster for me to just flip the switch at the back of the PSU. Im not sure if this is harmful, but it takes so long to shut down. I just get the little blue spinning dots saying "shutting down...". But, no issues with turning the PC on.
Also, I tried overclocking my CPU to see if performance improves, but when getting the i7 8700k to 5 GHz, as soon as I click start in the standard OCCT stress test, temps jump to 100 and the PC crashes (not bluescreen, just desktop freezes and needing to manually shutdown and reboot). I tried a slower clock with lower voltage and still jumps to 100 and crashes.
BIOS settings are set to default.
Thanks for your reply! I appreciate the help.
How old is your H100i v2 AIO? The temps immediately spiking to 100 degrees celsius would indicate to me you have a cooling issue. It could be your AIO pump is failing, which is a common issue w/AIOs.
Oooo, yeah, its getting old. I hadn't thought of that actually. Its roughly 3-5 years old. I don't remember when I got it; it was an upgrade from the Hyper 212 evo. Its like my memory was just wiped.
