Eyefinity Build Questions.
TokyoGenesis
13
I sold my old rig to start on a new fancy 3 monitor eyefinity setup. However I have not kept up too closely with stuff that has changed since my last build, so I figured I would come here and get some advice. I am wanting the eyefinity/gaming at high resolutions, to be the main focus of this build. Here is what I have currently selected:
Case: Corsair 600t
Powersupply: Corsair Modular 650w Professional Series
Motherboard: Asrock z68 Extreme4 Gen3 LGA 1155
CPU: i5 2500k
CPU Fan/Heatsink: Coolermaster V8
RAM: Kingston HyperX Grey Series 8gb (2 x 4gb)
Graphics Card: Sapphire Toxic 6950 2gb
HDDs: 750gb WD Caviar Black
60gb Corsair Force Series 3 SSD as a boot drive
Monitor- 3x 21.5 Acer S211HLbd LED monitors
How well do you think this rig would run ultra high resolutions for games?
If your going 3 monitor setup here I would suggest doing 2- 580's or 2- 6970's. Yes it's a bit more but IMO if your going 3 monitor set up then armrest run all games at high to MAX settings. I'm in the car so I can't get you prices but the 580 is around $450ish each bur again... Much better gaming experience.
Btw this will give you ultra settings :)
I think that would probably manage most games on mid settings @ 5760x1080. What i would do though is try to get another HD 6950 2GB in there. Possibly get a cheaper hard drive and CPU cooler. Maybe lose the SSD. Either way i think youre going to need 2 of those to play at ultra high settings.
Its really an open budget. The more expensive the parts, the longer its going to take me to save money. At this point though, I think I may yield better progress in this build if I go with one big monitor at 1920x1200 rather than a 3 monitor eyefinity setup.
