Eyefinity on 3 vga monitor
shenzron
6
Hello,
i have one sapphire hd 6970, it has 2 mini dp port, 1 hdmi and 2 dvi connector.
how i want to make eyefinity to my 3 vga monitor.
can i use this setup :-
dvi -> vga
hdmi -> vga
minidp -> vga
thank for your help.
DVI -> VGA
DVI/HDMI -> VGA
MiniDP -> ACTIVE adapter -> VGA
Its working? I do a lot of reading about this thing..some of them say, eyefinity cant work on 3 vga monitor, its must have 1 or 2 monitor that support digital signal.
That true? I'm little bit confuse here..
thats why the dp adapter has to be active...
I already put 2 dvi-i -> vga adapter but only one monitor work, from what I read, second dvi port at GC (bottom one) is purely digital..cant convert into a analog signal.
as i understand it- hdmi is pure digital. you cant go passivly to vga from it.
so if your card has dvi, hdmi and dp- you can dvi>vga pasivly only.
you'd need
hdmi>vga active adapter, and
dp>vga active adapter
I see..btw can i use 2 minidp active -> vga ?
hdmi active -> vga hard to find at my place..
