Hello everybody I hope you all are good.
I have tested motherboard/cpu/ram/psu/cables and everything seems to be working fine. no ez debug led was on, but after installing MOBO and other components inside the case, ez debug led turns on (CPU). when I power up the computer.
I have tried disconnecting system panel connectors one-by-one but didn't fix the issue. I have also made sure that CPU ATX cables and the rest were properly plugged in.
Please what should I do to overcome this issue ??
I hope to find some help in this forum. and I apologize if my English is a bit confusing and weird.
Here are my PC parts :
CPU : Amd Ryzen 4300GE
MOBO : MSI B450m pro vdh max
RAM : (G.Skill Aegis 8gb 3200mhz)x2
PUS : (MSI MAG A550BN // CORSAIR CX-550F RGB )
Case : Cougar mx410 mesh-g rgb
SSD : Intenso SSD SATA III 256gb 2.5"
