[SOLVED] F / 2 vs F / 2.2 - Does it matter? And how?
Oct 2, 2021
Hi, I'm writing here instead of the smartphone section because my question is about the focal aperture of the Selfie Camera on an Android device. I Hope you can help me!
Briefly, to you, between two different lens opening, with the same and identical camera, hardware, software, etc. both 20 Mpx, which would be preferable between an f / 2 and an f / 2.2, for semi-professional (entry level) pictures?
I already know that the difference will probably be minimal, but which focal aperture I should pick for more realistic colors and well-defined photos / self pictures, in all lighting conditions (even artificial) and at night?
Really thanks to those who will answer 😊
Which aperture setting you choose depends on the particular lighting at that particular moment.
There is no singular 'best'.
Try them both, in the same lighting conditions.
