FA: Working Asteroids PCB with speed mod
Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade.marketplace (More info?)
Any chance you would like to document that speed-up hack?
tm
The speed-up can be achieved with a daughter board or from a hack.
For the hack:
A simple modification allows you to select a faster speed for your
Asteroids game. This will provide more challenge for those locations
where the skill level is high.
You will need some 30 gauge wire and a switch.
1. Clip and lift pin 4 of C5 (74LS161)
2. Wire switch as follows:
* Common to lifted pin 4
* Normally closed to pad where pin 4 used to be connected
* normally open to pull up resistor next to C5
NOTE:
1. Be sure you wire the end of the pull-up resistor *not* tied to +5V.
2. Clipping any other pins besides pin 4 may have adverse effects on
Audio, Video, and/or coin discrimination.
Mike Fox
Algonquin, IL
mikesarcade_at_comcast_dot_net
> tm
I don't believe this is the same hack, and to be honest, I didn't mod this
board, I got it this way. I will try and document it tonight if I get a
chance though.
Rob
<mikesarcade@comcast.net> wrote in message
news:1115238908.921001.188980@z14g2000cwz.googlegroups.com...
> For the hack:
> NOTE:
> Mike Fox
> Algonquin, IL
>> tm
