[SOLVED] Facing Display glitches on Windows 10 newly built system - What could be the problem?
Apr 25, 2020
7
The PSU should be adequate. The GPU could be defective (I suspect this is the issue).
I assume you aren't trying to overclock anything (CPU, GPU, memory). If so, revert to stock speeds.
