Hi,
A boot drive recently failed on me: I noticed lag when accessing the filesystem, and after rebooting the OS refused to load. I've booted to a liveUSB and the disk shows up and can be read by recovery software, but after a few minutes any attempt to read from it results in 'input/output' error.
All the partitions show up in /dev/sd*, but it doesn't get mounted by Ubuntu. I tried running ddrescue on the boot partition, but after copying a few hundred MB all subsequent reads fail. Similarly, I could open gparted and see the partition table but after a few minutes it would also complain of input/output errors. I've done this a handful of times and it seems pretty reliable.
I've read of the so-called 'freezer technique', and since my drive seems to fail as a result of extended use, I'm wondering if getting it very cold might make it usable for long enough to recover my data. But I'm obviously hesitant at the idea of putting the already sensitive hardware under such intense stress, as well as the risk of condensation. I guess this should be a last-ditch attempt, but is there anything else I can try before that? And if I do eventually go the freezer way, can anyone recommend how long to leave it in there? I would think the less cold it gets, the less risk of condensation. How long should it be chilled for me to hope for some improvement?
