i believe this is everything important i've done to the pc
crash under load (first time ever)
restart
crash under load
failed to restart - fans spin + lights blink but no display or beeps
restart 20min later (assumed overheat)
crash under load
failed to restart after overnight
new mobo, cpu + ram installed
launches into bios fine
(various problems failing to get win7 to work)
format hdd and install win10
system works fine w/ gpu
multiple restarts due to driver installations incl. gpu drivers - no issues
crash under load
restart
crash under no load (just discord call + 2 chrome tabs)
remove cmos battery to reset bios
replace gpu with older gpu (no psu pins only mobo power)
launches fine
put everything in pc under load (only 50W psu draw) - no issues
my current specs are
gigabyte b360m d3h mobo
i5 8400 2.8ghz hex core coffee lake
2x4 2666mhz ballistix sport LT ddr4
amd radeon r9 280 3gb GPU (the backup one im using now is a radeon hd 6670)
700W psu : rs-700-acab-d3
first glance it looks like the gpu is failing somehow, but having just forked out for the other replacements i'm hesitant buy more parts without knowing for sure. have checked and rechecked all cables, reseated all components, dusted components throughout. usually i'd keep working at it but after 3 days of scrolling through boards like this one for various issues i'm ready to give up
also worth noting that if i fully unplug the gpu i can launch on dedicated graphics no problem
any help/advice appreciated
UPDATE: bought new PSU as that was next on the list to replace anyway - issue persists. considering the GPU is now the only old thing still in the machine i guess it can't be anything else. a bit bummed out it looks like i have to buy a new gpu as well, is there anything else it could potentially be?
restart
crash under load
crash under load
crash under load
restart
launches fine
