Question Fake1050 Ti, please help with vbios, I can't get a refund ?
Looking at all the pictures i could find, it looks to be the gts 450 rev 2 card.
Bios 70.26.26.00.00 is what your going to need LINK
it says that text what that mean
C:\nvflash>nvflash64 -6 217953.rom
NVIDIA Firmware Update Utility (Version 5.814.0)
Copyright (C) 1993-2023, NVIDIA Corporation. All rights reserved.
Checking for matches between display adapter(s) and image(s)...
Adapter not accessible or supported EEPROM not found, skipping
NOTE: Exception caught.
Results:
Index | Match | Flash | Name
<00> GeForce GTX 1050 Ti (10DE,1C82,0000,0000) S:00, B:01
Nothing changed!
ERROR: Detecting GPU failed.
then i still try maybe i can fix i just want to play lol
Even if you could find a working BIOS for this GPU, which is very difficult considering how much the thief modified this GPU in the first place, it'll be a cheap, 15-year-old GPU and you'll get better performance from whatever you're using now to access this forum, including your phone.
