R Robox Distinguished Jun 7, 2014 85 1 18,535 Mar 19, 2016 #1 you know what it depends on this problem and how to solve? http://i68.tinypic.com/iqycma.png
Solution barto Mar 21, 2016 Well those issues are typically GPU related. Sometimes the latest drivers aren't the best. Try a different one.
barto Splendid Apr 20, 2009 5,465 0 27,960 Mar 19, 2016 #2 What are you system specs? Upvote 0 Downvote
R Robox Distinguished Jun 7, 2014 85 1 18,535 Mar 19, 2016 #3 Quad-core Intel I5 + HD6970 (Crimson 16.2.1)+ 8GB DDR3 + W8.1 x64 Upvote 0 Downvote
barto Splendid Apr 20, 2009 5,465 0 27,960 Mar 20, 2016 #4 Can you be more specific? What i5? What power supply do you have (make and model)? If you don't know, open your case and read the label. What settings are you playing on? Have you tried a different set of GPU drivers? Upvote 0 Downvote
R Robox Distinguished Jun 7, 2014 85 1 18,535 Mar 21, 2016 #5 PSU CM 650M, I5 750, latest amd drivers, setting from medium to ultra Upvote 0 Downvote
barto Splendid Apr 20, 2009 5,465 0 27,960 Mar 21, 2016 Solution #6 Well those issues are typically GPU related. Sometimes the latest drivers aren't the best. Try a different one. Upvote 0 Downvote Solution
