I am slowly adding more fans to my HAF 932 w/ EVGA 470.
I want to add either an exhaust/intake fan on the bottom of the case but wondering what way I should orient it.
Took this before the cable management you can see in image one, but gives a rough idea of whats going on.
The GPU fan blows down from the top of it. I have the stock 230mm fan on the side and front, as well as the h50 push-pull as intakes.
The top 230mm is the only exhaust.
What do you think I should do? My 5.25" bay has a DVD Drive/Fan controller. Rest are clear.
Right now I am overclocked at 4ghz on an i7 950 full load is 75C in prime95. Want to bring this down more and think that my problem is I do not have enough exhaust (especially with the H50 pulling air in and it getting hotter through the radiator).
