Hi folks,
I have a Cooler Master Cosmos S case and I recently bought two more 120mm fans in addition to three stock fans (plus there's one 140mm and one 150mm for the CPU heatsink), so this is my current configuration right now:
There's an additional 200mm fan on the side panel, which I had to remove due to its collision with my oversized CPU cooler (Thermalthake Silver Arrow), but let's pretend it's there:
So, what would you change if it was your configuration? Would you set 200mm side fan to suck air from outside to inside or vice versa? I'd like to hear your opinions, thanks in advance!
