Question Fan connection
Jun 3, 2020
I have a Phantek Glacier C350A that I need to connect for the RGB, thing is I just want to connect that to a power cable and not to a hub. My motherboard does not support this I have an Asus crosshair v formula z. Any ideas guys.
May 10, 2020
92
9
45
You understand that you won't be able to control it without a compatible motherboard? Just powering it on will not display colors or will be set to a static color.
You could use a molex to 4-pin RGB header if you desired.
